1. Located mounting hole for transponder antenna, Ted P/N 11-17995. 2. Punched and drilled with #40 bit. 3. Back drilled with 1/2" bit. 4. Deburred,a nd opend hole slightly. 5. Treaded antenna through from below. 6. Placed mounting nut on top of antenna and tightened.
Note: transpoder is to be installed later, so the antenna cable was not added at this time.
