Brief Description: Right Side Boot Cowl and Instrument Panel
Fabbed up right side skin stiffeners and transfer drilled. Fabbed up spacers for right side skin. Taped and clamped right side lower [art of side skin to belly skin and transfer drilled. Modified instrument panel frame and temp riveted it to fuselage. Cleco instrument panel to frame and straighten tabs on firewall and instrument panel frame per figures manual. Will have to remove panel and frame to trim panel some more and install shim between tab and panel frame for clearance to fuselage tubing.
