Located left and right side skins. Transfer drilled through fuselage tabs. Aquired 1" pipe and formed side skins, bottom radius. Measrued cut and drilled left side stiffeners, installed on fuselage and transfer drilled to skins. Taped left bottom skin to belly skin and transfer drilled through stiffener. Fabbed and installed shims as needed to maintain skin formity.
