Russ Karnap
Date: 12-18-2018
Number of Hours: 8.50
Brief Description: Left Wing - Primed Stall, Skins, Rib... CS Main S
Installed nutplates on AOA/Pitot Heater.
Finished countersinking Main Spar and touching up Rear Spar dimples. Also, CS AOA/Pitot Mast Base to accept the skin dimples.
Finished dimpling Skins.
Primed all skins EXCEPT Leading Edge Skin. Primed Stall Warner parts, Access Plates, Wing Walk Doubler, W-423 Splice Plate, and inboard most LE Rib. Touched up scratched area on Main Spar Web.
Clecoed LE Ribs onto LE Skin in cradle. This skin is not primed.
Dimples
Rear Spar Dimples Touched Up
Stall Warner, Doubler, Inboard LE Rib, Access Covers
