FInished installing the pitot tube and tied all the wires and tubes up off of the covering. Tested the pitot heat and the wingtip strobes with a 14v battery. Everything works great. Sanded and then cleaned the top of the wing with MEK. Cut more polyfiber and tacked it in place with poly tack. Then I used the small iron to smooth out all the glued joints. After that it was on to the big iron, which I recalibrated. I used it to go over all the covering and heat shrink it with the low setting of 250 degees for an initial shrinking. Looks good. Lots more work to do, but it looks like a real wing.
