DId the final heat shrinking to 325 degrees on the whole wing. Looks nice and tight. Then I coated the entire wing with a coat of poly brush thinned 3 to 1. Seemed to get just the right amount to coat and fill the weave with a little pooling underneath without dripping. After that dried I had Ted help me snap chalk lines to line up the rib stitching and poked the intitial holes in the covering where the stitching cord will go. Ted also brought over extra needles, including the bent one I will need to stitch.
