Getting ready to cover the fuselage. Ran the wire for the tail beacon, trim position sensor, and the trim motor. Torqued the nuts for the flight controls and did some cotter pins. Also made two hooks wrapped in heat shrink tubing for the rear most baggage floor since I will have great difficulty getting in there after covering. It just slips over the frame and the front has the bolts. Not much weight will ever be back there.
