Torqued and cotter pinned more nuts today. Put more thread lock on the nuts to show if they move. Cleaned out the garage and moved the fuselage in there so I have room in the shop to cover the wings. Started working on wiring and pitot static line routing for the left wing. Cut the pitiot tube mast and heated and bent the top so that I can tap it and run bolts up through the bottom of the mount to hold it in place. The mast had some orange paint on it and it will be sanded off and primed soon. Cut the wing mount out of two layers of thick, hard balsa wood that will be hysoled in place tomorrow then epoxy varnished. The mount is turning out very nice, but it will be difficult to get at and fix once mounted.
