Finished trimming and drilling and deburring the center console sides. Bent the top edge slightly to conform to the console top, with a rubber mallet over the side of the workbench. Test fit the seat pan after trimming a little around the edges to make it sit on the cross tubes. Sat in the airplane for the first time. Couldn't get a good selfie, so I had to wait for the photographer and I changed by then. Re cut the rudder stops to try to get them to the 25 degree mark, and over shot to about 40 degrees. I can add a softer stop on them to keep the paint from peeling every time they hit so it will work out.
