Brief Description: Seat pan trim, cable interference
Worked on trimming the seats to fit. Lots of cutting and sanding wearing protective gear. Installed the nutplates to hold the seats in place. Noticed a clearance problem with the bottom of the seat and the aileron control tube. I should be able to adjust it out later when rigging the flight controls. Also noticed a problem with the rudder cables and the center console and floor boards. I will cut the floorboards and push out the center console sides for final mounting. Everything is a tight fit.
