I angled the quadrant to allow the cable to pass behind the flap and brake handles. I installed the mixture control below, but later moved it to below the panel as the upholstery will interfere with this placement. P.S. I've since replaced the mixture control shown with one that has a center button lock, as there wasn't enough friction on the simple push/pull control to keep the mixture set where I wanted it.
