Received replacement tires from Wicks, so I finally mounted the tires and tubes on the wheels. I bent the brake cable routing tubes to better point to the brake lever on the wheels. Drilled and riveted the cable guide in the spar box. Routed the brake cables. Also assembled the PTT switches in the Ray Allen control grips.
