I was initially stumped when fitting the vertical stab, as I couldn't see how you could get the forward attach fitting in place without enlarging the cutout. I checked other builder sites and determined that you need to make it quite a bit larger. The forward part of the tail fairing will eventually tuck under the cutout, so the cutout will be visible. I'll have to see what others have done here.
