Richards Web Site
Date:  9-4-2006
Number of Hours:  6.00
Brief Description:  Cowling - rough cuts
Time for the last character builder in the project -- the cowling. I marked and cut out the cooling openings and prop hub. I used a saber saw where I could, and then used a Dremel with a roto-zip type of cutting bit, worked fine.As I got closer to the finished line, I switched to a 1.5" diamond disk on the Dremel. Makes a nice clean cut. For the cut on the firewall, I first put masking tape flush with the forward edge of the side fuselage. Next place the cowling in place, overlapping the tape. Put a second layer of tape on top of the first. Run down the edge of the tape on the cowling with a Sharpie. Remove tape and trim to line....leaving a 1/8" or so extra for final fit. (This will compensate for the bottom layer of tape which does not lie flat due to the rivets.)
Rough cutouts marked (upside down)
Initial fit before trimming
Tape used as a guide
