Per Tony's suggestion I mounted (2) 5/8" alum tubes as wiring conduits between the tank and the glare shield. One will be for EIS, the other for all else. The tubes goes thru the upper firewall. I also mounted the RV air vents amd trimmed the flap handle by about 1" to clear the vent hose.
