Robin's RV8 Web Site
Date:  2-11-2013
Number of Hours:  1.00
Manual Reference:  Antenna
Brief Description:  Antenna Fittings
Com. 1 GTN 750 Comant CI-122 VHF
Com. 2 SL 40 Comant CI-122 VHF
Transponder GTX Comant CI-105 XPD
Nav. Comant CI-157P VOR LOC
OAT GTP 59
GPS GSU 750 GA 35 GPS/WAAS
GPS GTN 730 GA 56
These are the main antenna, the Coms are installed in the first inspection cover on both wings, the OAT in the middle inspection cover, the Transponder in the passenger control stick bay (easy to access) and the VOR in the Aft Bottom Skin. These locations are determined by the need to keep the Com. Antenna 3’ apart and the Txpndr antenna with a 3’ ground plane and a distance of 3’ from the remoted txpndr on the rear battery tray. They all have back plates of 0.063 2024 T3 Aluminium as dictated by the manufacture’s instruction. The avionics are high quality so let’s have high quality performance, there is no point in degrading it’s performance by poor antenna placement.
Com, / Wing Insp.
Com, / Wing Insp.
Inspection Cover
Inspection Cover
VOR / GPS
VOR / GPS
