The Vans supplied baffles were cut down for use with the Plenum. The supplied diagram that came with the Plenum for making your own baffles seemed to come out about right though there were a few minor alterations. The fuel distributor, the spider, did have to be dropped lower to clear the Plenum. This was done by a slightly increasing the bend in the support bracket and re-drilling the bottom hole of the bracket.
