To create a reasonable C of G with the Odyssey Battery on the firewall, the remote transponder and remote Mountain High Oxygen bottle is installed on the mounting area for the rear battery mount; it uses the same installation bolt holes. The new mount comes in two pieces, both manufactured in 4130 aircraft metal sheet. Julian Stokes’ Precision Sheet Engineering manufactured them in his remarkable workshop using computer laser / press machines and Peter Lingertwood’s Unicol powder coated the paints to perfection. A huge amount of time and effort, beyond the call of duty, was put in by Julian to create these parts to perfection. And Peter once again turned the parts around in 24 hours with perfect powder coating. It’s not possible to stress my thanks to them.
