The Canopy Plexiglas was started during a period of ‘needing to get away from the worries of the Canopy Frame installation and the Anchor Block’; an even bigger stress procedure than the frame. All seems to go as advertised. The Canopy was trimmed close to the red line down the sides with bigger margins at the front and rear. The next trimming will start to be more interesting. Much time was taken in setting up the Anchor Block for drilling of the holes which drilled ok. The Anchor Block was fully installed at this time and not left till later as per the instructions. The Frame was needed to be solid before drilling the Slide Rails.
