The Rear Rudder Pedals require holes or share holes in the Centre Structure / Cabin Braces / Cover. Using Click Bond not only saved time but also allowed the nutplates to fit into this tight place; all very easy.
It seems that a slight bend is required on the aft end of the cover to make it sit flat on the Centre Structure and a second bend for it to fit onto the Mid Longeron.
