The assembly of the Pitch Bell crank, the Baggage Rib Angle and the bulkhead was straightforward. But, to install the TruTrak, no instructions, required further looking at other builder site with the same RV8 series kit. A further spacer was fitted on the bell crank where the servo control rod attached in order to stop the two sides of the bell crank pinching. And a small slot was filed to enable the servo support rod to clear the Baggage Rib Angle; another builder with a similar series kit depicted this on his build site.
