The Rosel Boys RV 8
Date:  4-2-2015
Number of Hours:  4.00
Brief Description:  Wheel Install
Installed Matco whells on axles and drilled cotter pin holes. Disassembled and installed tires/tubes. Grease all bearings w/aeroshell #5 grease. Installed tire/hub assembly on axle an secured wheel nut with cotter pin. Installed inside brake shoes. All brake assemblies set to 100 in-lbs. Tagged all connections with orange torque seal
