Brief Description: Fuel pressure and quantity calibration
Filled plane with fuel. Calibrated fuel pressure with mechanical gauge between last injector and fuel pressure regulator. Set to 35 psi on Garmin to match mechanical fuel gauge.
Found fuel sending units were not working properly. Removed both sides and repaired. One had a wire disconnected and the other needed its float wire adjusted to fall with gravity.
