Drilled and set front wing attachments, installed fuel tank vent lines to fuselage fittings, rigged and trimmed flaps for proper fit to bottom of fuselage, riged up 12V power source and set/cycled flaps for proper travel, set ailerons to neutral with jig and control stick then adjusted all linkages as required for a perfect fit. Installed wing root fairings
