The Rosel Boys RV 8
Date:  7-12-2015
Number of Hours:  30.00
Brief Description:  Access Door and Misc Wiring
Installed electronics shelf outboard of left rudder peddle and mounted EFII's ECMs and MAP sensors.
Cut large hole for wire harness through firewall and mountaed capture plate with nutplates for easy maintenance.
Began routing wires to engine components, spark plugs, etc
Received baggae compartment avionics access door from Cleveland tool and installed on bulkhead F-866B-1 as per sub kit instructions
installed garmin fuel psi sensor to fuel psi regulator, oil psi, and MAP psi to manifold on firewall. Purchased longer MAP line from Aviall and instaled from engine to firewall manifold.
