Rogers Sonex Site
Date:  2-13-2013
Number of Hours:  7.00
Brief Description:  Contols - brakes, rudder cables
I hooked up the rudder cables .. aligned rudder and nosewheel so everything is straight.
I finished the brakes .. filled them. Still having a little trouble getting a bubble out of the left one. I'm filling them from the bottom up which
normally works. Might just need the rudder pedal at a different angle when I'm filling it.
I spent some more time on the cowling .. covering over the rivet heads. It's a lot of work .. but will be nice to have them covered.
I need to get some fuel and see if the engine is going to startup.
