I have to wait for a new skin so I thought I would work on the skeleton today. I clecoed and drilled the spar reinf. plates and platenuts to the spar. Clecoed and drilled the tip rib, counterweight rib, counterweight skin and counterweight. Clecoed and drilled the Horn, root rib and trim spar. Now when the new skin arrives I will match drill it to the skeleton then debur dimple and prime these parts along with the parts to the right evevator.
Spar, reinf. plates and platenuts
Tip rib, counterweight rib and counterweight skin.
Skeleton showing the horn, trim spar and other assemblies.
