I built the adapter bracket for the prop brush assembly. The installation of the Gen 3 is underway. I installed a new pilot bearing, drive spline, plate and dowels.I then slid the Gen 3 into place. Just a little persuasion needed...very little. Everything lined up, so I bolted and torqued everything. I then installed the brush bracket adapter. Then the starter went on. I tried it and it was in proper location. I installed the temperature sensor. I filled the greabox with 16 oz of 75w90 Lucas synthetic gearlube. I reprogrammed the Flyspeed prop controller to the new 2.02 to 1 ratio. Tomorrow I'll wrap the install up, and fire it up.
