I removed the rad/air intake assembly and drilled a hole for the air intake temp sensor. I then made washers and a special nut for it. Loc-Tite and tightened. Routed, connected and secured the wiring for the sensor. I routed and secured the wiring for the block coolant temp sensor. I secured the elevator trim speed control with 3M strip.
