Brief Description: left wing stringers & strobe light adaptors
I worked 11 hours over the last 4 days installing top and bottom stringers. Also finalized the strobe light adaptors. I've made 2 wood blocks that I cut 45 degree, then I put 2 blind nuts to be able to screw the strobe light from the outside without the need to hold the nut inside. The big sqare hole in the center is to pass the electrical connector. I then secure the wook block inside the wing tip by applying fiberglass cloth and resin on it.
