I removed the wing from the table and lay down the left wing bottom skin then predrill it using the right bottom skin as a template. After the drilling job, put the right wing frame back on the table, squared it and set the washout. Put the bottom skin back in place and drilled all the holes to 1/8 size. Clecoed
