Began to position the nose skins. I measured carefully where to drill on the nose skin then I made a template out of extra material from one nose skin and predrilled all the leading edge skins. I traced a line in the middle of the nose ribs in order to be able to position them correctly. Lay down each piece, drilled and clecoed the bottom side wich is in the up position. Looks good.
