Finalized struts. When I did the wing set-up, I only drilled one hole at each end of the strut in order to set the right lenght. Now I drilled the two other holes, deburred and primed. I used 3 bolts AN3-14A with one washer at each end.
Also fixed the plastic guides for the pushrods on the cabin ribs.
The aircraft is now back in the factory for the next step.
