Bob's Searey LSX Web Site
Date:  9-19-2021
Number of Hours:  0.75
Manual Reference:  *Chapter 30
Brief Description:  Propellor bolt torquing
One of the final checks prior to starting the Rotax engine for the first time was to ensure that the propellor was properly torqued.
When I had earlier assembled the prop I set the blade pitch to the recommended 12 degrees and tightened the bolts just enough to hold them in place. Now I torqued the blade clamp bolts to 120 in-lbs and the prop mounting bolts to 175 in-lbs as specified in the Searey manual, which seems to be lifted right out of the WarpDrive (my prop) manual.
Let's get this baby spinning!
