Bob's Searey LSX Web Site
Date:  10-28-2023
Number of Hours:  2.50
Manual Reference:  Dynon 7-47
Brief Description:  Engine tacho wire resistor
The tacho reading bouncing around at readings over 5,000 rpm was quickly solved by Googling some forums and then finally (duh!) reading the Dynon manual page 7-47. They recommend installing a 60k ohm resistor between the engine trigger coil and the Dynon EMS pin 32. I put together a used 100k ohm resistor (all that I could find in my small town) and that did the trick, until it failed, when I found another pilot who, miracle of miracles, had dozens of new resistors that he was only to happy to share. Finally, an easily resolved problem
100k ohm resistor components
Assembled
Assembled
Installed
Installed
