Over two sessions I installed the two lower gap seals which mount at the top of each side of the pylon and close the gaps between the wings and the pylon. They mount fairly easily with sheet metal screws and Timmerman nuts. Over another two sessions I installed the upper gap seal which closes the big gap between the fronts of the two wings. This gap seal comes in a flat sheet that has to be positioned in place and bent into shape from the bottom side, around the leading edges and back along the top side to tuck under the radiator. It also mounts with sheet metal screws and Timmerman nuts. This is probably best done as a two person job due to the reaching overhead and the need to hold, bend, drill, and place screws. But I managed by myself.
