Wow! I am flying now (at the assembly table, if not in the air yet) - a one man Boeing assembly line I tell ya! Just 1.5 hours to assemble the two Frise Aileron Frames. I used a combination of the manual instructions, which refer to the standard aileron frame, and PA drawing C-1000-XXX-Version 1.0-Revion A, which details the new Frise Aileron Frame. May 30 update: For the Frise Ailerons you need to install the three nutplates of step 1 on the top side of the Aileron Leading Edge, not on the aftside as you would for the old style ailerons.
