More work completed today on the Rudder "final finishes". I installed the Trim Tab, the Rudder Horn, the Rudder Horn Stops and the Cables that control the Rudder and the Tail Wheel. 10 August update: in the third photo below you can see a piece of green masking tape that is reminding me to replace the bolt with a drilled one, castle nut and cotter pin, this I did today
