Bob's Searey LSX Web Site
Date:  8-8-2021
Number of Hours:  2.50
Brief Description:  Fuel System - first fuel flow
Success!
I put 5 US gallons of premium auto fuel into the tank (less than a quarter full) and let it stand over night to check for obvious leaks in the bottom portion of the fuel system. The next day I disconnected the 5/16" fuel inlet hose at the engine's mechanical fuel pump and rigged a temporary fuel catching pitcher in place.
Then with fingers crossed and a fire extinquisher in hand I turned on the electric fuel pump. It quickly stopped chattering as it pulled in fuel and discharged it through the hose into the pitcher.
The only downside is that I couldn't get any flow out of the Primer Bulb which is used to pump the Fuel Tank Sump over the side. Maybe it needs priming, or a fuller Fuel Tank?
Supreme Plus gasoline
Fuel line visible in the tank
Fuel flow into pitcher
