Now knowing that the sliding canopies have been assembled and work (except for the trailing edge braces) and that the cabin windows are also able to be finalized I decided to remove the clecos holding on the windshield and install some of the rivets. Along the bow deck joint I used 3/16" aluminum rivets and along the top tube connection I used 1/8" steel rivets, as called for in the manual.
