I had purchased a Brothers electronic label maker specifically for labelling the panel switches. However in digging through all the brochures that I had brought back from Oshkosh 2015 I found a decal sheet, provided by EAA I believe. It had many pre-printed labels that seemed to provide a lot of what I needed. So, these I stuck onto the dash, the centre console, the emergency fuel valve location, and the starting carb lever (overhead). Good enough, for now. I also applied the "EXPERIMENTAL" decal to the co-pilot/passenger side of the hull as mandated by Transport Canada. This decal came with the PA kit.
