Continuing my efforts to get the sliding canopies not to interfere with the turtle deck I temporarily installed the co-pilot cabin window, using clecos on the inside. This did not remove the interference. I then removed the window so that I could readily access the backside of the turtle deck bulkhead for its re-installation, and the wiring in the bottom the hull (bilge pump, trim actuator) for final check-out and securing.
