Bob's Searey LSX Web Site
Date:  5-21-2017
Number of Hours:  18.00
Manual Reference:  *Chapter 39
Brief Description:  Electrical - Cockpit Area
We got another four days of detail work under our belts terminating the electrical wiring harness in the cockpit area; cleaning up the J7 wire bundle in particular between the D-Sub and the switches; connecting up the Gear Relays; remounting and connecting the Capacitor; tidying up loose connections in the X bundle (Starter, Relays, Grounds, Shunt, etc); hooking up the V bundle (Gear Switch, Gear Lights). I used a lot of 2-pin Molex connectors for the V wire bundle which doesn't go through the Harness Tray but directly to the Centre Console and decided to solder then as well as crimping. In the future, when I check all the other Molex connections throughout the plane I will solder them too.
And now it is time to pack up the hangar again as we are off on a new project assignment, this time in Europe. The plan is to return for a week in August and finish all the electrical except for the yet to be ordered instruments (Dynon, Radio, Intercom, Transponder). The best laid plans...
Lots to solder
Lots to solder
Centre Console
Centre Console
J3, J5, J7 D-Subs to panel
