With the mounting of the Wings coming soon it was time to decide on the final location of the Engine Voltage Regulator and the Engine Ground Strip. After a lot of musing I decide to put the Regulator on the co-pilot side of the Root Tube under the Oil Reservoir. Here it can be mounted & removed relatively easily, the wiring is short and it is not in the way of anything (I hope this all bears out to be true). The Engine Ground Strip I mounted just ahead of the Regulator, anchoring it to the aft Radiator support leg. I then tied up all the wires and cables on both sides of the Root Tube, tie wrapping them together and keeping them all inside the Radiator supports.
