One more electrical panel fabricated today. This one is for the Master Relay, Starter Solenoid and the Shunt and is located on the right side of the bow near the battery. I used a couple of lengths of 1/16" aluminum 1" angle, a piece of .025" aluminum sheet, some SBL4-4 rivets, a AN3-13A bolt (with a plastic spacer, washer and locking nut) and a couple of #10 - 3/4" sheet metal screws. It is fixed to hull bow stiffener panel at the front and the re-inforcement block on the hull bottom to the rear.
