Installing the two Inertial Reels for the 3-Point Safety Harness went a lot easier than I thought it would. Knowing I was going to be reaching and working inside the Turtle Deck made me aprehensive, but things went fairly well. Even the fact that the 1/4" mounting hole was not pre-drilled in the Mid Root Support turned out to be not much of a problem. The old manual specifies the location further up the Mid Root Support than the new manual does. I went with the latter and drilled through with ease. The new manual provides for all sorts of Fender Washers and Spacer Blocks that the old manual doesn't. Since the spacers were included in my kit I followed the new manual and installed them. Presumably they keep the pilot side strap clear of some obstruction such as the Flap Actuator lever.
