This was pretty simple stuff installing the Bow Eye, the Static Ports, the Brake Line Grommets and the Bilge Pump Hose through-hull connector. The two Hull Drain Plugs were installed some time ago. I am not installing Bow Lights so that complicationwith more hull penetrations that can leak water is avoided.
