Brief Description: Electric Trim Actuator - checking
I had actually started checking my earlier installation of the Electric Trim Actuator back in November but found I had to order drilled bolts AN4-26 and AN4-30. These arrived and I installed today - see the first photo. I had tried to drill the thread end of an AN4-26A bolt using a wood block and a 5/64" drill in my drill press with no luck.
The Push Rod on the Trim Position Sensor took a little fiddling and ended up as show in the third photo.
