Bruce now finished off the Wing Strut that Hardik started back on 26 April and also the complete second one. He had some head scratching moments about the aforementioned (see 26 April log entry) Channel Bracket but also over the changed part numbers for the Wing Jury Strut, Aft and the Wing Jury Strut, Forward LSA. On the parts supplied in my kit they are numbered 5720-006 and 5720-026 respectively not 5750-020 and 5720-002. The inserts that go into some of the ends of the Jury Struts are installed in the factory as noted in the manual. One insert also came with the Eyebolt, AN43B-04A already screwed in complete with a Nut, 1/4-28 Jam, Stainless instead of the Washer, AN4 called for in the manual step 7. We took this as a hint from some helpful LSA factory build worker and followed suit.
