Brief Description: Rudder/Throttle assembly - part 7 - pedal springs
I had installed the rudder pedals into the frame prior to installing the frame into the hull, which precluding me from carrying out Section 10 step 21 which is hooking up the Rudder Pedal Springs... a simple satisfying step that I can do now that the frame is finally in the hull... but should have left for a drop-in visitor to do as sort of a ceremonial 'sod-turning'.
